It is currently Sun Jul 13, 2025 1:04 pm
PostPosted: Thu Jan 03, 2019 5:00 pm
As per title ausminiers. Currently removing the engine from my 850. Any tips on disconnecting the magic wand shift? All my manuals don't show anything besides remote and rod.
PostPosted: Thu Jan 03, 2019 7:44 pm
if I post the wrong answer, someone will correct me... the stick has a plate over it held in with 2 bolts, undo the bolts and the stick and plate come out. You should be able to get to them after you take the plate off the floor on the inside
SP #64 has a picture of the back of the box, but no useful description other than "remove the hex screw and spring"
PostPosted: Thu Jan 03, 2019 9:01 pm
Correct Simon. Once you remove the plate and rubber boot there are two bolts holding a plate that retains the gearlever.
PostPosted: Thu Jan 03, 2019 10:11 pm
Thanks guys, appreciate your help. Car is up on stands currently and has easy access to the bolts on the plate.
