It is currently Sun Jul 13, 2025 12:59 pm
PostPosted: Wed Dec 26, 2018 12:59 pm
The engineering drawing for the Cooper S (and Clubman GT) rear seat brace specifies a change to the way the RH fuel tank bracket was secured from 4 Feb 1971. If you have a Cooper S with a 2/71 or later build date on the ADR plate could you please check the method of securing, welded or bolted, and report back?
PostPosted: Thu Dec 27, 2018 3:01 pm
Hi Winabby, I’ve not got a 71 S, but here is a pic of a 8/71 build GT. Spot welded bracket as per drawings.
Hope this helps.
PostPosted: Thu Dec 27, 2018 3:26 pm
Hope this helps.
Thanks for that. Confirms what has been discussed on Clubman GT Facebook groups that all GT's had the spot-welded bracket. The current initiative is to work out if and when it was implemented on a Cooper S.
PostPosted: Thu Dec 27, 2018 6:22 pm
Hi, My 71 S car no 2915,body no 2399 one of the last lot with anti burst handles was definitely bolted.
Ben
PostPosted: Fri Dec 28, 2018 12:00 pm
Cars 2853 and 2891 are bolted on.
PostPosted: Fri Dec 28, 2018 2:15 pm
So it appears the spot-welded bracket may not have appeared until Clubman GT production.
PostPosted: Fri Dec 28, 2018 4:00 pm
Could have been a cost cutting method to shift to spot welding on the Clubman GT??
Thats a fair bit saved spot welding, from installing the bolt brackets and nuts as done on the Cooper S's.
Users browsing this forum: timmy201 and 84 guests
