It is currently Sun Jul 13, 2025 12:48 pm
PostPosted: Thu Oct 25, 2018 4:14 pm
Any tips on removing the ingnition/steering lock from the steering column.
PostPosted: Thu Oct 25, 2018 5:52 pm
A) Cut a slot in the screw heads with a hacksaw or a Dremmel and use a screwdriver.
B) Use a centre punch to undo the screws.
PostPosted: Fri Oct 26, 2018 9:21 am
C) drill a hole in them and use an easyout - the ONLY time I recommend using an easyout...
PostPosted: Sun Oct 28, 2018 8:21 am
If removing permanently (as we did for our 71 Clubby getting centre speedo) use Mr Anglegrinder.:)
PostPosted: Sun Nov 04, 2018 7:50 am
Wasn't the actual steering Column lock one of the ADRs of 71?
So removing steering lock permanently makes the vehicle non compliant ! Yes ? No ?
"Let us remove your "SHORTS"
PostPosted: Sun Nov 04, 2018 10:41 am
PostPosted: Sun Nov 04, 2018 9:13 pm
Some 71 Clubbies still had the centre speedo binnacle and switchgear. No steering lock.
PostPosted: Mon Nov 05, 2018 11:37 am
So it could depend on what ADRs this car has stamped whether it is legal or no :?:
PostPosted: Mon Nov 05, 2018 12:08 pm
ADR plate is optional. Not needed for NSW registration if missing...;)
Who would check this anyway. It's a club car.
PostPosted: Mon Nov 05, 2018 3:24 pm
Thanks guys there is no ADR plate for this car 1970 registration.
Users browsing this forum: Bing [Bot] and 70 guests
