It is currently Sun Jul 13, 2025 2:03 pm
 Post subject: Tail light part numbers
PostPosted: Mon Oct 15, 2018 2:32 pm
Can anyone tell me the part numbers for the Lucas Australia tail light assemblies that have the reversing light built into the orange turn indicators? That's 2 screw, small tail light 1970ish round-nose - not the later clubman style.
PostPosted: Mon Oct 15, 2018 3:19 pm
Lucas 62957126 (RHS) and 62957127 (LHS). Also known as BMC part numbers AYA9149 and AYA9150 respectively.
They are exactly the same as AL136 non-reversing light bases except the single filament bulb holder is replaced by a twin filament bulb holder, same item as used in the stop/tail position. The easiest and cheapest way to make reversing light bases is to rob the stop/tail socket from another AL136 base or a Clubman base. The edge of the socket can be carefully prised off and then pinched back on the new base.
PostPosted: Tue Oct 16, 2018 9:25 am
Thanks winabbey.
Doing just that!
