It is currently Sun Jul 13, 2025 9:44 am
PostPosted: Sun Oct 14, 2018 5:41 am
Saw this on an English site.
http://mk1-forum.net/viewtopic.php?f=5& ... 5ad5746c32
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
PostPosted: Sun Oct 14, 2018 2:30 pm
not really relevant here, as those kits are for the Mk3 onwards
and in reality the Oz windup windows are better for air-flow through the cabin than any sliding window, especially at low speeds
PostPosted: Sun Oct 14, 2018 9:12 pm
I have often heard this comment about poor airflow in a sliding window mini.
However, I have one and am surprised by how good the airflow really is.
Depending on how much you open the front or rear half of the door windows and also the rear windows you can have a howling gale through the car.
I don't know how much better it could possibly be 8)
PostPosted: Mon Oct 15, 2018 7:48 am
+1
Cheers, Ian
PostPosted: Mon Oct 15, 2018 8:12 am
How do they go at the Toll Booths, Carwash or Burger Joint drivethu's :?: :P
PostPosted: Mon Oct 15, 2018 2:48 pm
the airflow is fine if your moving, but when you are in traffic crawling along its horrid
PostPosted: Mon Oct 15, 2018 8:13 pm
There are no toll booths any more, keep them closed in the carwash :shock: , they still open up half the window for the maccas drive through :wink:
PostPosted: Tue Oct 16, 2018 6:16 am
Sure...OK, add car park boom gates where you take a ticket :roll:
PostPosted: Tue Oct 16, 2018 6:41 pm
With the drive thru I find it's not so much the sliding windows but the fact the roof of the mini is a similar height to the bottom of the drive thru window
PostPosted: Tue Oct 16, 2018 8:37 pm
Was it the mini Sunshine that had a sunroof ?. They could just drop your order down to you :D
PostPosted: Fri Oct 19, 2018 7:04 am
Yes they did...as did many other Mini's fitted with after-market sunroofs...the idea of having your order dropped down to you is a little scary tho :)
