It is currently Sun Jul 13, 2025 5:00 pm
 Post subject: Windshield washer
PostPosted: Mon Oct 08, 2018 1:44 pm
What, where size hose do I buy and T-fitting to connect my washer to the nozzle?
1973 Clubman GT - YG2S8 1637
 Post subject: Re: Windshield washer
PostPosted: Mon Oct 08, 2018 1:48 pm
Over here any decent auto parts shop will stock the hose on the roll and should have T-pieces too. It is sometimes called vaccum/washer hose and comes in various sizes. Do you have any chain outlet parts shops over there?
PostPosted: Mon Oct 08, 2018 1:56 pm
we have NAPA auto parts but I doubt they carry the T-fitting. The T-fitting has 2 different size connections.
PostPosted: Mon Oct 08, 2018 2:32 pm
NAPA have this one as an example - different sized barbs on each end, cut off the small end if using the next size up hose. Works for 1/8, 1/4 and 3/8 hoses
https://www.napaonline.com/en/p/NDP7151816
PostPosted: Mon Oct 08, 2018 2:47 pm
was the original washer hose black or clear?
PostPosted: Mon Oct 08, 2018 5:18 pm
Clear
PostPosted: Mon Oct 08, 2018 5:24 pm
Try a pet shop that sells aquarium supplies....
Cheers, Ian
PostPosted: Mon Oct 08, 2018 7:21 pm
gtogreen1969 wrote:
Clear
Early minis (1966 to 1970 at least) were green tinted pvc. I don't know about Clubman series.
I think that's why aquarium suppliers are suggested as green tubing was used so as not to scare the fish.
PostPosted: Mon Oct 08, 2018 7:34 pm
Bill B wrote:
gtogreen1969 wrote:
Clear
You might be right. Most of the ones I have seen were clear brown so I assumed they were originally clear to start with. I will see id I can dig up a few pics.
PostPosted: Mon Oct 08, 2018 7:52 pm
Here are a few GT washer hose pics if needed.
PostPosted: Tue Oct 09, 2018 10:44 am
My K had green hose originally and I've got the old green ones from the '66 S in a box here.
PostPosted: Tue Oct 09, 2018 11:23 am
Is that clamp available?
PostPosted: Tue Oct 09, 2018 12:50 pm
I have not seen that clamp for sale by the usual mini shops. There are plenty of similar steel line clamps available through other outlets but they look slightly different.
PostPosted: Tue Oct 09, 2018 1:15 pm
You might be able to find a brake or fuel line "P" clip that is pretty close. Otherwise just make one up?
https://www.est1946.com/stainlesssteelf ... lamps.aspx
http://www.trojanparts.com.au/index.asp ... 2145860226
