It is currently Sun Jul 13, 2025 11:49 pm
 Post subject: Loose Drive Shaft
PostPosted: Fri Oct 05, 2018 7:54 am
My Mini has hardy spicer uni joints. When I shake the drive shaft, there is play in output shaft and the seal. Is this caused by the nut being loose on the output shaft?
 Post subject: Re: Loose Drive Shaft
PostPosted: Fri Oct 05, 2018 8:49 am
Or the bush in the side plate.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Oct 05, 2018 3:02 pm
or the bush in the diff housing / crown wheel?
PostPosted: Sat Oct 06, 2018 3:37 pm
Can this be sorted with the engine in the car?
PostPosted: Sat Oct 06, 2018 4:22 pm
Side cover yes, diff bush no.
5/72 Clubman Gt
PostPosted: Sat Oct 06, 2018 10:12 pm
Often you find the drive flange is worn unevenly, as well as the cover bush worn. It's unusual to find much wear on the diff cage bushes.
Replacement side cover bushes are all made undersize and need their bore machined after fitting.
If the drive flange is worn it can be turned down a few thou then the bush bored to suit. Allow 1-2 thou clearance.
