It is currently Mon Jul 14, 2025 2:16 am
PostPosted: Mon Sep 10, 2018 6:38 pm
What have people on here done to make doors fit/close better with new door rubbers. The lower corner is not flush with the body. I'm thinking of spacing out the hinges where they attach to the body.
Any thoughts?
PostPosted: Mon Sep 10, 2018 8:26 pm
Any thoughts?
Are you sure the door doesn't have a twist?
PostPosted: Mon Sep 10, 2018 9:04 pm
And you have the correct rubber? There are differences to my knowledge.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Sep 10, 2018 10:50 pm
That's how most of the doors and boot lid fit. I have regapped my C. S. which and I now have excellent gaps even the bonnet fits well. I did this when the body was in epoxy primer. To get the gaps correct I used a cross pein hammer curved planishing hammer and 2 small dollies no welding ,stretching edges and tapping back panels, NO body filler. Most concourse minis have bad gaps on all the panels. The starting point is new pins and bushes in the hinges, You can twist the door and make sure the door fits correctly to the rear side panel. To do the twist use a piece of timber wrapped in a rag hold the timber either at the bottom of the door so it contacts the sill panel, or waist height depends which way the door needs twisting, the exert pressure on the door .All old cars have bad gaps have a look at an old Mustang I spent 4 days fixing gaps on a car that ended up a concourse winner.
Allen
PostPosted: Tue Sep 11, 2018 7:41 am
None had perfect gaps from the factory either. Some better than others but that's what you get with mass production and assembly lines. They do look good with nice gaps but a bit of character doesn't hurt either!!
5/72 Clubman Gt
PostPosted: Tue Sep 11, 2018 7:43 am
Stibbsy, is it the lower corner furthest from the hinge that is the issue? Are the other 3 corners good? If so a little twist on the door might be the trick as p7676 mentioned.
5/72 Clubman Gt
PostPosted: Tue Sep 11, 2018 10:14 am
Yes, lower corner on both doors. Both hard to close.
Sorry, upside down. Can't seem to fix.
Fixed by mod
PostPosted: Tue Sep 11, 2018 1:05 pm
Bend inwards the lower flange which the door seal attaches to, use a small block of wood and hammer. It may crack the paint where the corner is, you can touch it up with a brush, also you don't see it. Remove the door rubber first on the lower flange and check if it closes better.
PostPosted: Tue Sep 11, 2018 3:29 pm
Still a little bit of adjusting to do. Thanks for the advice! I don't know where I'd be without this forum.
