It is currently Sun Jul 13, 2025 6:37 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Fri Sep 07, 2018 7:55 am
Got to be happy with that , how much better does it look 8) .
PostPosted: Fri Sep 07, 2018 9:32 am
I agree look how ugly it was before
1973 Clubman GT - YG2S8 1637
PostPosted: Sun Sep 09, 2018 12:38 pm
I am building a pressure bleeder for my mini so i can bleed the brakes by myself. I need a cap for the reservoir i feel bad drilling thru this one and installing a hose fitting on it. Any suggestions? I also need the rubber inside the cap
PostPosted: Sun Sep 09, 2018 3:41 pm
One trick was to clamp a block of thick rubber over the tank. Some pressure bleeders kits came with one.
PostPosted: Sun Sep 09, 2018 4:38 pm
I tried to do the same but drilled the hole in the centre of a used cap. Problem was the schrader valve sat too close to the bonnet gutter to get an airline chuck onto the valve. Might work if you used a bicycle pump to pressurise the reservoir.
PostPosted: Sun Sep 09, 2018 8:54 pm
PostPosted: Mon Sep 10, 2018 11:01 am
Nice This would be too tall for the brake master cylinder. I will work this out after this Typhoon headed to Guam
