It is currently Sat Jun 21, 2025 9:39 pm
 Post subject: Morris 1100S blocks
PostPosted: Thu Sep 06, 2018 7:05 pm
I have acquired a couple of 1100S blocks. The blocks with no Cooper S back plates. Were they all thin, thick or a mixture of flanges? Cheers.
 Post subject: Re: Morris 1100S blocks
PostPosted: Thu Sep 06, 2018 7:15 pm
Mix. Also some were large journal cranks and some were small
PostPosted: Thu Sep 13, 2018 7:27 am
Thin flange ones all had the small journal crank and S rods. So did early thick flange ones. From around 12YDTaH10500 they got the big journal crank and heavy lump rods.
Even the thin flange ones are much stiffer than a Cooper S block.
No need to tap flange holes bigger IMO. They don't leak there.
