It is currently Wed Jul 16, 2025 6:09 am
 Post subject: Removing output shaft
PostPosted: Thu Aug 23, 2018 10:02 pm
Hi all,
Trying to remove diff output on the RH side to fix a leak. Just need to know if I’m doing it right I don’t want to break anything. Have a bar made to hold the flange. Is it normal rh thread?? Won’t come with 1/2” rattler, should I move to 3/4” gun? Thanks
PostPosted: Thu Aug 23, 2018 10:26 pm
It's a normal RH thread. Torqued to 70 lb/ft.
PostPosted: Thu Aug 23, 2018 11:15 pm
Thanks mate. I’ll continue to hold it with the bar and try the bigger rattle gun.
PostPosted: Fri Aug 24, 2018 8:48 am
Use a socket and a breaker bar. Cheap rattle guns are useless.
Don't take the side cover off or you will dislodge the shims.
Just pry the seal out with a narrow screwdriver.
PostPosted: Fri Aug 24, 2018 10:35 am
Ingersoll-Rand Titanium 3/4” drive, nuff said haha!
Tried breaker bar but no good. Unfortunately have to take housing off because it needs a repair and new gasket
PostPosted: Fri Aug 24, 2018 11:25 am
If the new gasket is thicker than the old you will need to add shims. I would have pulled the motor if it needs this.
Bugger to do in the car...
PostPosted: Fri Aug 24, 2018 2:14 pm
yep, pain in the arse....
9 bolts and a roll pin :lol:
PostPosted: Fri Aug 24, 2018 7:34 pm
Haha yeah point taken!
Got the nut off, 3/4 rattle gun sorted it. I’ll measure the gaskets and hopefully they’re the same thickness and no shimming needed.
PostPosted: Fri Aug 24, 2018 9:55 pm
Recent black gaskets for the last 15? years are about .015" compressed. Original brown ones were less than half that. You would need to add about a .010" shim if so.
Hint- put grease on the shims so they don't dislodge as you refit the cover.
Users browsing this forum: No registered users and 33 guests
