It is currently Mon Jul 14, 2025 7:33 am
 Post subject: Wiper motor question
PostPosted: Wed Aug 15, 2018 4:34 am
Hi All,
Here is my wiper motor currently on the mini. I thought it should be a 2 speed but it’s only got two wires coming out of it. It could have been modified or it could be from some other car, not sure. If it’s only single speed then I’ll be on the lookout for a 2 speed to buy if anyone has one. Thanks.
1972 Mk3 Mini 1000, 1150cc supercharged.
https://www.ausmini.com/forums/viewtopic.php?f=3&t=95872
 Post subject: Re: Wiper motor question
PostPosted: Wed Aug 15, 2018 5:10 pm
That is a UK motor, be aware the switch and its wiring are totally different to Oz 1 or 2 speed motor setup.
PostPosted: Wed Aug 15, 2018 5:21 pm
attached to a UK car ;)
viewtopic.php?f=2&t=97594
leave it alone until the car is registered....
PostPosted: Wed Aug 15, 2018 6:36 pm
Yes Simon I know this, it sounded like he wanted a local 2 speed motor...
PostPosted: Wed Aug 15, 2018 7:54 pm
Thanks guys just trying to get my ducks lined up before rego and they’ll probably require 2 speed wipers. Wasn’t aware that the uk ones were differentt o Australian. I can buy a UK one from minisport uk and fit my gears to it. I’ll just wore up a toggle switch with a relay, I found a tutorial on the net with wiring diagram. Thanks again
PostPosted: Wed Aug 15, 2018 8:01 pm
Googling that Lucas part number 54071664 seems to confirm it's a single speed unit.
PostPosted: Wed Aug 15, 2018 8:16 pm
I wonder if you can convert your unit to two speed by simply replacing the brush set? This NOS item has three wires so would seem to be for two speed. No idea if it suits your motor though.
https://minikingdomonline.com.au/produc ... er-motors/
PostPosted: Wed Aug 15, 2018 8:55 pm
Thanks that’s a good idea. I see mine only has 2 brushes. I would also have to buy a park switch and the wiring plug, or just buy a new wiper motor.
PostPosted: Thu Aug 16, 2018 9:51 am
That motor is also Mirror image to local Mini item.
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 84 guests
