It is currently Mon Jul 14, 2025 8:37 am
 Post subject: Interior indicators
PostPosted: Sat Aug 04, 2018 10:57 pm
Hi there all
My binnacle green indicator lights both go on when the left or right indicators are put on. They are also not as bright as well.
Maybe a short?
Has anyone had a similar problem?
Appreciate any thoughts
Thanks
 Post subject: Re: Interior indicators
PostPosted: Sat Aug 04, 2018 11:05 pm
Could be the flasher can playing up.
Whats going on with the indicators outside? Are all 4 coming on at the same time?
PostPosted: Sat Aug 04, 2018 11:16 pm
No the outside indicators are fine
PostPosted: Sun Aug 05, 2018 12:23 am
Try cleaning up all the connectors and plugs for the indicator switch and flasher can and see if that helps.
PostPosted: Tue Aug 07, 2018 8:08 pm
i've had the same problem on my Mini K, i was trying to use an electronic flasher can & it was doing the same
thing as what you have said, i'm now using the std can type flasher unit & i've got no problems now, hope this helps you out
PostPosted: Tue Aug 07, 2018 8:30 pm
If this is on a 2 pin flasher unit type system, You have the earth between the two warning lights missing and they are lighting up in series Getting half the voltage each.
"Let us remove your "SHORTS"
PostPosted: Tue Aug 07, 2018 10:40 pm
Thanks all. I will try your suggestions on the weekend
Thanks again
PostPosted: Sun Aug 12, 2018 5:36 pm
Replaced the flasher cam problem solved!
Thanks all
PostPosted: Sun Aug 12, 2018 6:37 pm
Some flasher cans have different connector lay outs, this can cause grief to the unsuspecting.
Users browsing this forum: justminis and 79 guests
