It is currently Mon Jul 14, 2025 3:44 am
PostPosted: Sat Aug 11, 2018 5:02 pm
Hello all ,does the door handle spring connect to the bottom screw on the handle ?after it slides over the shaft.
TY Allen
PostPosted: Sat Aug 11, 2018 6:18 pm
the Australian supplement of the big red workshop manual has this to say....
Reverse the above (disassembly) procedure making sure that the door handle return spring arm is in the downward vertical position. Preload the spring by moving the spring arm through 90° to locate on the spacer under the forward securing screw
not as good as a picture 'eh :D
PostPosted: Sat Aug 11, 2018 10:02 pm
thanks simon maybe someone has a pic
