It is currently Mon Jul 14, 2025 2:44 pm
 Post subject: Under chassis paint
PostPosted: Thu Aug 02, 2018 10:30 pm
Folks, currently restoring a mini van. What would be the best under chassis paint available. Something that I can paint over with 2 pac or acrylic. I hate rust so I prefer something rubberised or chunky. Thanks for the advice.
 Post subject: Re: Under chassis paint
PostPosted: Fri Aug 03, 2018 6:33 am
Do you mean the body deadner?
PostPosted: Fri Aug 03, 2018 7:32 am
Sounds like it.
There are plenty of options out there. Have you spoken to your local auto paint supplier?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Aug 03, 2018 1:28 pm
I used Gravi Tex plus.
http://www.u-pol.com/uk/en-uk/product/upol/coatings-uk/specialist-coatings/gravitex-plus-hs-stone-chip-protector
You can't drive your shares on the weekend...
PostPosted: Fri Aug 03, 2018 2:52 pm
Timinik wrote:
Saw this at my local paint shop..looks like thsi is the way to go....
PostPosted: Fri Aug 03, 2018 2:53 pm
Scoop wrote:
Sounds like it.
Thanks Scoop. Had a look today...
PostPosted: Fri Aug 03, 2018 5:28 pm
The only one to use is stone guard which is used on modern cars It will have the same finish as the original coating. Most of the proofcotes will soften and bleed through the paint. Most professional restorers use stone guard because it has the best adhesion plus other advantages.2 pac is the way to go if you can afford it, also use a 2 pac epoxy primer on the whole car.The stone guard goes over the primer. Easy to apply.
Allen
PostPosted: Fri Aug 03, 2018 7:58 pm
Allen
Allen, thanks. I will look for it.
