It is currently Sat Jul 12, 2025 11:57 am
 Post subject: Heater question.
PostPosted: Sun Jul 29, 2018 10:00 am
Just wondering if someone can tell me what this heater is out of, was told it was early mini, but has a date of Sep 10 69 stamped on it, nothing else visible. Have tried a search, but nothing look like it. Has a sliding hand operated vent.
1974 Leyland Clubman
Lots of good machines
Of all the things I have lost, I miss my mind the most.
 Post subject: Re: Heater question.
PostPosted: Sun Jul 29, 2018 12:10 pm
Not sure what they're from but my 66 van had one in it when I got that. Seemed like a basic fresh air type that required you to be moving before any benefit!
I put in a converted moke heater instead!!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jul 29, 2018 12:23 pm
Yes that is what it looks like to me, I was just going to add a 12v computer fan behind it to get some warmth.
Graham
PostPosted: Sun Jul 29, 2018 3:45 pm
Were these 'fresh air heaters' standard fitment to late 60's Deluxe models? Or an option only?
PostPosted: Sun Jul 29, 2018 4:03 pm
The fresh air heater fitted as standard to minimatic and optional for deluxe and 850 was a different type:
PostPosted: Sun Jul 29, 2018 9:33 pm
I always assumed that it was just an aftermarket item, fitted up to my van for some warmth. Some warmth, not a lot!!!
5/72 Clubman Gt
PostPosted: Sun Jul 29, 2018 9:39 pm
Mini k’ s have them as well.
PostPosted: Sun Jul 29, 2018 10:03 pm
"Mini k’ s have them as well."
My '69 didn't, had nothing. My '70 and '71 had a good heater with fan and air deflector (demist or floor setting) below the dash. Was also fitted to the '71 Cooper S, (not sure about the '70). The heater controls were on a steel bracket bolted to the parcel shelf to the right of the steering column. Heater valve is inside the car, not on the cylinder head..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri May 31, 2019 8:06 pm
Do you know if the cores are avail ? I seem to remember seeing them advertised in the UK .....but maybe they were different
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sat Jun 01, 2019 10:15 am
I fitted an Attwood 3" bilge blower in the flexible duct where it goes onto the firewall.
A bit noisy, but it works. Only needed in traffic.
PostPosted: Sat Jun 01, 2019 1:05 pm
These were only fitted to local cars so I wouldn’t think there would be any in the UK?
