It is currently Mon Jul 14, 2025 10:04 am
 Post subject: Quarter vent pivot
PostPosted: Tue Jul 24, 2018 8:57 pm
What is under the nut at the pivot stem? I thought there was a washer and spring.
Mine is packed with about six 1/4" shim type washers.
 Post subject: Re: Quarter vent pivot
PostPosted: Tue Jul 24, 2018 11:02 pm
Thats correct, although I seem to remember they're belleville (cup) washers to add some spring effect to the pivot. They're held in with a nyloc nut, and you can get a small socket ratchet in there to adjust the pivot resistance.
PostPosted: Wed Jul 25, 2018 7:36 am
So if you can get a ratchet up inside the door can you adjust the resistance??
PostPosted: Wed Jul 25, 2018 8:33 am
Certainly can. A 1/4 drive ratchet does the job perfectly.
PostPosted: Wed Jul 25, 2018 10:26 am
Thanks! Quarter vents are out. Just fitted new rubbers and have to get hinge repair kits and lock springs & pins. Can't seem to find any info on the pivot stems.
PostPosted: Wed Jul 25, 2018 2:33 pm
was it an absolute nightmare fitting the new rubbers? I was so traumatised I've only done one side!
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Jul 25, 2018 5:04 pm
Thanks. I’ll have to give it a try.
Users browsing this forum: Bing [Bot] and 95 guests
