It is currently Sat Jul 12, 2025 11:52 am
 Post subject: Gearbox Rebuild
PostPosted: Fri Jul 20, 2018 11:10 pm
Has anyone experienced rebuilding a 22G846 gearbox with the contents of a 22G1128 gearbox, in other words has anyone turned a 22G846 gearbox into a Mk2 4 synchro gearbox and if so what are the results. I ask the question because everything I have found on google says it is possible and I am thinking I will give it a go.
 Post subject: Re: Gearbox Rebuild
PostPosted: Sat Jul 21, 2018 8:18 am
If google says you can then it must be true.
PostPosted: Sat Jul 21, 2018 8:56 am
What is the aim of this? They are both 4 synchro gearboxes, the 22G846 just seems to be an earlier casting?
PostPosted: Sat Jul 21, 2018 10:25 am
I have rebuilt both they are practically identical.
I have also put A series early rodchange gearsets into 22G1128s, everything is the same except the reverse idler gear.
PostPosted: Sat Jul 21, 2018 4:07 pm
what was the 22G846 fitted to out here?
the only 4 synchro remote gearbox casings I've come across have been 22G1128
PostPosted: Sat Jul 21, 2018 8:03 pm
Simon,
The one I rebuilt was out of a pov pack clubby 1100 I think.
It had the puddin stirrer long gear lever.
PostPosted: Sat Jul 21, 2018 8:20 pm
I have pics of 2. One was listed as a Pov Pack clubman and the other as a Morris1100. Info was from the sellers on Ebay.
PostPosted: Sat Jul 21, 2018 8:42 pm
I just picked one up last week. Previous owner put in a cooper s gearset in, central oil pickup and magic wand shift! Perfect for my 66 vans engine build! 8)
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sat Jul 21, 2018 9:49 pm
very handy!
PostPosted: Sun Dec 09, 2018 5:23 pm
Is the reverse idler gear from a rod change box interchangeable with a remote change 4 synchro box?
PostPosted: Sun Dec 09, 2018 5:53 pm
No, they are different.
Remote: 22G1034
Rod (pre A+): 22G1852
PostPosted: Sun Dec 09, 2018 6:55 pm
Re the use of Cooper S MK2 gears in a 4 synchro remote or rodchange box:
The 18T 1st motion shaft and 22G1040 cluster gear are getting scarcer and expensive now.
An alternative at around 1/2 the price is keep the original gears, and fit a 3.1:1 diff.
This gives you the same 1-2-3 gearing as an S, but a taller 4th. Better cruising on the motorway. :)
Edit typo
Last edited by drmini in aust on Fri Mar 01, 2019 4:28 am, edited 1 time in total.
PostPosted: Mon Dec 10, 2018 8:26 am
The 28T 1st motion shaft and 22G1040 cluster gear are getting scarcer and expensive now.
Clever Kev! 8)
PostPosted: Thu Apr 18, 2019 4:39 pm
Has anyone experience in using CLASSIC MINI - REVERSE GEAR STRAIGHT CUT - C-22A1736 in lieu of 22G1034. Are there any differences apart from the tooth count.
PostPosted: Thu Apr 18, 2019 7:52 pm
Clever Kev! 8)
They go good. I run the same spec under my 1360.
Sent from my SM-J530Y using Tapatalk
