It is currently Mon Jul 14, 2025 8:57 am
PostPosted: Sun Jul 08, 2018 6:06 pm
Hi All,
Big thanks to all for the amazing info and generosity in sharing and helping those less mechanical.
So, I’ve been soaking the heavily corroded tie rod ends in CLR for the past few days to give them a clean up.
Tragedy though, the original springs that seal the rubber covers over the top of the tie rod end have been corroded through ( pic below). I’ve been looking to find something to replace them on the mini sites but can’t find anything. Other that replacing the entire tie rod end which seems silly just for the springs.
Anyone know of a solution?
Brendon Image
Zulu...
1967 mini Cooper S
PostPosted: Sun Jul 08, 2018 6:19 pm
Do they come on the new boots?
http://www.classicmotoring.net.au/cmos/ ... ucts_id=56
PostPosted: Sun Jul 08, 2018 6:45 pm
timmy201 wrote:
I have just replaced mine whilst dismantling front hubs / bearings , the new boots didn't come with springs but i suppose you could run a bit of tie wire around the boot if you wanted to .
PostPosted: Sun Jul 08, 2018 8:24 pm
No, no new springs.
It’s very frustrating.
Surely there’s something out there that’s similar!!
Wire will be my last resort.
Maybe someone will know of a solution.
B
Zulu...
1967 mini Cooper S
PostPosted: Sun Jul 08, 2018 9:24 pm
When a complete new tie rod end is $17.45 I see them as a consumable part, they are pretty much always replaced whole. I've never replaced a boot on one yet. The boots make a good seal for rod change shifter boxes though!
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Wed Jul 11, 2018 10:22 pm
Replacement torsion springs found on TE boots. Job done.
Zulu...
1967 mini Cooper S
Users browsing this forum: No registered users and 66 guests
