It is currently Mon Jul 14, 2025 8:44 am
 Post subject: Tie Rod Ends
PostPosted: Sat Jul 07, 2018 1:17 pm
Hey Dudes,
Am working on the tie rod ends as I need to replace the rubber boots. Just wondering if they need to be packed with grease and if so which sort?
B
Zulu...
1967 mini Cooper S
 Post subject: Re: Tie Rod Ends
PostPosted: Sat Jul 07, 2018 2:03 pm
If in doubt use molygrease. Castrol LMM or similar.
PostPosted: Sat Jul 07, 2018 8:47 pm
“Who’s the doctor they told you to go see”... not Dr. Dre
Dr Mini!!! ^ this guy. Awesome.
Thanks Kev
Zulu...
1967 mini Cooper S
PostPosted: Mon Jul 09, 2018 9:36 am
and if you have the slightest doubt about their wear or condition...throw some new ones on :idea:
PostPosted: Mon Jul 09, 2018 10:40 am
I'm thinking that will be the option... One of the tension springs has broken due to corrosion and I can only seem to buy a replacement from China in lots of 10,000... That would mean I have 9,999 to store in the shed! more than all the tie rod end tensions springs needed in the world!
And at cheap cheap to replace them... why wouldn't I?
B
Zulu...
1967 mini Cooper S
PostPosted: Wed Jul 11, 2018 10:21 pm
Replacement torsion springs found on a set of TE boots. Job done.
Zulu...
1967 mini Cooper S
