It is currently Thu Jul 03, 2025 8:16 am
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Thu Jun 28, 2018 9:40 pm
Firefirey wrote:
Doug. May I ask what the colour is called or batch numbers are for the red/brown for the inner wheel rim ;-).
I tried but they don't want to hand out the mixing formula. They can make and send paint anywhere around Australia.
I can spray a sample and send to you if that helps. I got a litre can and a spray pack for each colour.
PostPosted: Fri Jun 29, 2018 12:34 pm
Some original S wheels came in grey primer rather than red....
Cheers, Ian
PostPosted: Sat Jun 30, 2018 6:16 pm
i have a set of oz coopers rims original paint if you need a paint match
Sent from my SM-J530Y using Tapatalk
PostPosted: Sun Jul 01, 2018 6:03 am
Cheers Doug :-) I'll make contact with kiwiinwgtn as that may be a little easier for all over here
Thanks for the offer.
Kiwiinwgtn could we make contact regards the colour on the inner Australian cooper s rims. Cheers
PostPosted: Fri Jul 06, 2018 9:13 pm
i sent you a pm using my phone. hope you got it
PostPosted: Sat Jul 07, 2018 8:45 am
Sent from my SM-J530Y using Tapatalk[/quote
Cheers, Thank you. Will be in touch.
PostPosted: Thu Sep 03, 2020 9:47 pm
Doug, I am in the process of restoring some S rims.
Can you supply the details / supplier of the paint you used?
Thanks
PostPosted: Thu Sep 03, 2020 11:51 pm
I can add more detail later
viewtopic.php?f=3&t=98057&p=1044375
PostPosted: Fri Sep 04, 2020 12:23 pm
None of the spray cans have the formula listed so best to contact Milsomes direct. They should have it on file.
PostPosted: Fri Sep 04, 2020 1:26 pm
Hi Doug,
Thanks for pointing us towards your build thread.
An excellent job on the car, as well as the thread.
Do you recall how many cans you went through to do the rims - 5 or 10 of them?
PostPosted: Fri Sep 04, 2020 2:43 pm
I think two of each did the job on five rims, plus one can of clear coat for the silver side.
PostPosted: Fri Sep 04, 2020 6:05 pm
Thanks, I will give them a call.
Users browsing this forum: No registered users and 116 guests
