It is currently Mon Jul 14, 2025 8:02 pm
 Post subject: Floor starter question
PostPosted: Thu Jun 28, 2018 11:09 pm
I'm sorting out all the bits in the shed in order to build a better gearbox than the one that came with the 850. I really like the idea of a between-the-seats gearstick but I also really want to keep the floor start button.
Can I have both?
Behold! The mighty 850!
PostPosted: Fri Jun 29, 2018 7:41 am
Yes. There is no problem with the remote shifter and a floor starter
I did have a problem initially with a larger diameter RC40 exhaust touching the live side of the starter button. I gave it a hit with a hammer and made a divot on the exhaust pipe to clear
PostPosted: Fri Jun 29, 2018 9:06 am
If you have the same exhaust set up then think about some heavy duty electrical/heat insulation for the switch body, its terminals and the cables possibly covered by insulated sheet metal :idea:
PostPosted: Fri Jun 29, 2018 11:36 pm
Nice. Thanks, lads.
I really love that button. It's so mid-last-century.
PostPosted: Sat Jun 30, 2018 8:46 am
They started using buttons on modern cars again, I think.
PostPosted: Sat Jun 30, 2018 9:20 am
Have you thought that you can spin the switch so the terminals are North and South instead of East and west. Gives you better clearance.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Sat Jun 30, 2018 9:21 am, edited 1 time in total.
PostPosted: Sat Jun 30, 2018 9:21 am
It does make a lot of sense when the battery is in the boot and the battery cable runs right under the floor. It means you can install the starter button there rather than a key and a solenoid/relay.
You can also crank the engine over with the key off so there is no chance of the engine starting if you want to build oil pressure or test compression
PostPosted: Sun Jul 01, 2018 8:43 am
I thought that as soon as I saw Timmy's picture!!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Jul 01, 2018 12:26 pm
With everything going 'keyless' these days, it's almost a logical step. It wouldn't be hard to do for ignition in a mini but those '62 door locks aren't going to open themselves, that's for sure.
PostPosted: Sun Jul 01, 2018 1:48 pm
The problem is (tho) that in the cut and thrust motoring of today...if you stall, and have to take your eyes off the situation you find yourself in, even momentarily...you are liable to get cleaned up by someone :roll:
As for modern cars...try crawling up a steep incline in the UK in a car that shuts its engine down...and don't re-start as quick as it should...throw in a foot operated parking brake and you have a recipe for a rolling backwards disaster :D
PostPosted: Sun Jul 01, 2018 10:12 pm
The wife's Golf is auto everything. Hill start, Hand brake, auto start after stalling and engaging clutch, Lights, mirrors...
All the stuff you'll forget to do when you go back to the poverty pack 850. :D
Users browsing this forum: Bing [Bot] and 90 guests
