It is currently Tue Jul 15, 2025 3:35 am
 Post subject: twin carbies 1970 cs
PostPosted: Sun Jun 24, 2018 7:12 pm
Just another rant about the carbies, seems difficult to tighten the rear nuts on the carbies ,do you use a grind down spanner ? 9/16 af
Allen
 Post subject: Re: twin carbies 1970 cs
PostPosted: Sun Jun 24, 2018 7:32 pm
I just use an open end spanner if the studs are too long. But I also remove the entire manifold with the carbies. I dont remove or replace the carbies with the manifold still fitted to the engine.
PostPosted: Sun Jun 24, 2018 8:34 pm
Allen
That's been my experience too. I think it's just 'mini: if you can see it, you can't touch it; if you can touch it you can't see it". Many modern spanners are very long and getting caught up on all the springs and cables is usual. I have to keep turning the open ended spanner over to get just 1/2 a flat at a time.
PostPosted: Sun Jun 24, 2018 8:57 pm
Admittedly I only have a single carb, but I bought Sumer stubby ROE from Supercheap just for working on the mini.
Surprising how much easier things are with them.
PostPosted: Tue Jun 26, 2018 4:16 am
I think the original nuts were not as thick as a normal nut .
I filed down some stainless nuts to fit my 1-1/2" twins .
PostPosted: Tue Jun 26, 2018 6:39 am
Are you able to point me to what you are referring to here?
PostPosted: Tue Jun 26, 2018 9:47 am
Go to Bunnings and buy a cheap short ring open ender spanner for $1 and cut the ring end off to make your own stubby.
IIRC the nuts are 5/8" AF.
Edit: Just checked and the nuts are 9/16" AF.
RonR
68 build Mk1 Cooper S
PostPosted: Tue Jun 26, 2018 10:14 am
The nut size on my carbies is 9/16 AF which means Across the Flats. Not the dia of the stud. I will check if there were smaller nuts used they would have to be 1/2 AF. You cant change the stud dia as you know. Pain to fit.
Allen
PostPosted: Tue Jun 26, 2018 11:59 am
Nuts are 3/8 UNF, 9/16 AF and around 5mm thick. Photo shows a cheap 1/2 cut open ended spanner that I've used for years. The carby set shown are from a Mini (jigsaw puzzle) I bought last year. Could not find the proper nuts so I machined down some thicker 3/8 UNF nuts to make them easier to fit.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Tue Jun 26, 2018 6:37 pm
These ones.
http://www.supercheapauto.com.au/Produc ... ece/342530
PostPosted: Tue Jun 26, 2018 7:58 pm
The nuts used on HS2 (1 1/4) carbs, as said above, are 3/8inch diameter (of the stud) UNF thread and use a 9/16inchAF spanner. I think they are called "half nuts" or "lock nuts". See minispares comment:
http://www.minispares.com/product/Class ... 0to%20shop
The HS4 carbs use smaller 5/16inch studs that use 1/2 inch AF spanners. These nuts are full sized.
PostPosted: Tue Jun 26, 2018 10:50 pm
good info
PostPosted: Wed Jun 27, 2018 6:23 am
These ones.
Well, I would never have found them from the previous description!
PostPosted: Wed Jun 27, 2018 7:05 am
I love the price. I have them mind for other little jobs too.
Lower rad bracket bolts, clutch cover, lower engine mounts...
PostPosted: Wed Jun 27, 2018 8:04 am
Stubby spanners can be very handy. The amount of spanners in ones toolbox though:
stubby, standard, long ring & open, ratcheting, offset ring, long ring ring. Goes on and on...
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
Users browsing this forum: No registered users and 42 guests
