It is currently Mon Jul 14, 2025 7:18 pm
PostPosted: Fri Jun 22, 2018 3:11 pm
I have a standard 998 and was thinking of just fitting a K&N pancake filter eventually fitting a stage 1 in the future.
At the moment I have the standard aac needle fitted. Will I have to change the needle if fitting the K&N or can I just richen the carb.
PostPosted: Fri Jun 22, 2018 8:36 pm
you probably won't need to make any change at all... you won't know until you put the filter in and put an AFR tester on it
