It is currently Mon Jul 14, 2025 9:52 pm
PostPosted: Thu Jun 21, 2018 7:15 pm
I dropped 1 spring when fitting carbies 1 hour later using mirrors and magnets I still have not found the spring. Anyone had this problem the spring fell about where the grease nipple is.
Allen
PostPosted: Thu Jun 21, 2018 7:50 pm
yes i did mine the other day it flicked off and landed behind the master cylinders
PostPosted: Thu Jun 21, 2018 8:14 pm
If i loose a part down the back of the motor and cant see or feel it then sometimes i will use the garden hose to set it free. Things can het hung up on the back of the block, on top of the diff housing, on the exhaust, in the Uni joints, on the remote housing, in the subframe. Or across the other side of the garage floor.
Users browsing this forum: Barkfast and 103 guests
