It is currently Thu Jul 17, 2025 3:04 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: Door Check Straps
PostPosted: Fri Jun 15, 2018 8:32 pm
cruiser23 wrote:
Doug, by the look of your photo the ends are doubled up, presumably for added strength at the bolt holes?
Yes, that's right.
PostPosted: Sat Jun 16, 2018 6:13 pm
On mine, both ends are doubled over for extra grip. The body side has a pressed metal plate to cover the doubled thickness of webbing, using 2 countersunk screws.
The door side is also doubled and uses a thick, flat bar and a round pin to hold the doubled webbing to the door. In Doug's photos, you can't see the flat bar and pin as the webbing covers it.
PostPosted: Sat Jun 16, 2018 6:25 pm
Like this ...
