It is currently Mon Jul 14, 2025 12:56 am
PostPosted: Mon Jun 11, 2018 9:16 pm
I had a clubby years ago standard The rocker cover flooded with oil.
all the rocker stuff would have been flogged I had no money young bloke.
the drain back is the pushrod holes. So increase drain or decrease oil flow
PostPosted: Mon Jun 11, 2018 9:18 pm
cam bearing upside down wasn't a factory feature was it?
PostPosted: Tue Jun 12, 2018 8:08 am
Quite possible back then Simon.The local guy we use here now is aware of that one
PostPosted: Tue Jun 12, 2018 2:49 pm
Today i removed a valve spring and valve seal to see where the top of the guide sits in relation to where the oil level in the head would sit. The valve guide sits almost flush with the top cylinder head surface. Which would mean that oil would always be pooled up over the guide and seal rather than just splashing onto them. I feel like valve seal isn't intended to seal against oil in this manner. What are you thoughts?
PostPosted: Tue Jun 12, 2018 7:03 pm
Holy crap My Elder head aint like that
Hi tech seals maybe .I feel your pain
Raise the guide then you limit lift I had pain getting longer pushrods .I can see why my head was made taller.
Taller valves Taller guides and shims maybe
That was done as a compromise to make it bolt on
I would rather have work to do and be told about it for a good result .
I think the Arden must be good as MED chose to sell it
PostPosted: Tue Jun 12, 2018 8:00 pm
Matt Reid or Graham Russell may have dealt with this .Give em a call.!
PostPosted: Tue Jun 12, 2018 10:56 pm
I'd be interested in the answer as I've not come up with a solution yet. I've fitted tighter seals to custom guides but mine still blows a bit of smoke at start up/idle. I've not looked into it too much further as it's only been on road for a couple of weeks. Have put 5/8" breather on rocker cover to eliminate that as an issue. I've read one post (that I can't find again) about a fella in Scotland I think who remachined the oil drain but other than that, very little info.
-Wasabi
1972 Clubman - Daily Driver
1962 850 - EW1 Powered
PostPosted: Thu Jun 14, 2018 9:43 am
Thinking i'm going to bolt the head back on just to mock it up and turn the motor over by hand to see how far the valve spring cap travels down. Im hoping that there will be enough clearance to push the valve guide up a little in an attempt to get it above the oil level. Will moving the valve stem up affect seating of the valve?
Also where can you buy better valve stem seals?
PostPosted: Thu Jun 14, 2018 12:00 pm
Xray head with a view of deepening the gutters prolly best fix
PostPosted: Thu Jun 14, 2018 1:47 pm
Karcraft stocks Viton seals. Plastic similar shape to Mini Metro ones.
Graham Russell stocks Viton seals with a brass body.
Edit Ian check your PMs, send me an SMS please.
PostPosted: Thu Jun 14, 2018 8:15 pm
Gotcha Kev Yes my turbo 3 litre supra used viton seals
PostPosted: Thu Sep 20, 2018 2:59 pm
Bit of an update (i don't get much time to work on the mini these days)
After contacting Graham Russell and explaining my situation, he suggested buying Vitron valve stem seals (metal base) from MiniPlus (These have a great seal against the valve stems) and loctite sealing the base of the valve stem seals to the valve guides.
So what was the result?
So far, so good...
On start up it blew smoke which was to be expected as a fair bit of oil made its way into the exhaust system, but as it warmed up and burn off the excess oil, the smoke cleared.
I have since started it up and ran it a couple of times with no smoke. Im unsure if this will be a long term fix as the valve seals may not be up to the task of sealing from oil levels above them after they wear a little. I'll just have to wait and see.
Thank you everyone for your help and for Graham Russell who was more than happy to take time from his day and help me out.
PostPosted: Thu Sep 20, 2018 3:26 pm
Viton seals last a lot longer than the originals or the ones in a Payen gasket kit.
PostPosted: Thu Sep 20, 2018 3:41 pm
Awesome result. I will fetch a set of these for myself as well and see if it works for me :D
-Wasabi
PostPosted: Thu Sep 20, 2018 4:49 pm
For those interested in these seals but can't be bothered searching:
https://www.minisplus.com.au/classic-mi ... ce-item-ea
