It is currently Tue Jul 15, 2025 1:18 am
 Post subject: Ignition Differences
PostPosted: Fri Jun 08, 2018 9:44 pm
It appears Mini kingdom ignitions and all I've seen on Google do not match my Mk2 ignition. My question is, are Mk2 ignitions different to other Mini's?
https://minikingdomonline.com.au/produc ... on-switch/
 Post subject: Re: Ignition Differences
PostPosted: Fri Jun 08, 2018 10:31 pm
What is the difference are you referring to?
PostPosted: Fri Jun 08, 2018 10:46 pm
There seems to be a chromed ring spacer missing on replacement ignitions.
PostPosted: Fri Jun 08, 2018 11:05 pm
Can you just swap the chrome ring extension over? As long as the threaded section is the same length there shouldn't be a problem.
PostPosted: Sat Jun 09, 2018 4:57 pm
The chrome spacer was introduced about 1969. Most Mk 1 Coopers did not have the spacer. I am not able to give any reason for the change except maybe it was easier to reach and also offered more clearance to turn the key. You may need to locate a second hand spacer. Cheers Jim.
PostPosted: Sat Jun 09, 2018 5:14 pm
Is there a part number for this chrome spacer and would the switch need to be longer than the standard switch.
I think I've seen them on the Mini K.
PostPosted: Sat Jun 09, 2018 6:53 pm
I think the switch is longer. I thought they were only on the Cooper S, I have a K with one and a K without... The one with the spacer has a somewhat more questionable history though.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Sat Jun 09, 2018 7:01 pm
Here is a period photo of a Sep 1965 Cooper S (sorry about the quality) and it looks like it has the extended ignition switch. I have looked through my photos of unrestored cars and it looks like every MK1 Cooper S had them.
PostPosted: Sat Jun 09, 2018 7:13 pm
I thought I sent an answer to this question a few minutes ago but it does not appear to have launched.
Basically I was saying what gtogreen has said. My '66 Mk1, '69 mini K and '70S all have that spacer. Photos from the competitions dept of early-to-mid '60s cars all have the spacer too.
PostPosted: Sat Jun 09, 2018 8:40 pm
More examples.
