It is currently Tue Jul 15, 2025 9:00 am
PostPosted: Mon Jun 04, 2018 7:34 pm
Hello All ,Which is the correct switch to use the white one that works from the brake pedal or the screw in switch on the brake line ?
TY Allen
PostPosted: Mon Jun 04, 2018 7:55 pm
TY Allen
Screw in hydraulic switch under the brake servo
PostPosted: Tue Jun 05, 2018 9:32 pm
While gtogreen is right about the hydraulic pressure switch in line and the original lucas units lasted well, aftermarket replacements are highly suspect and I've had several fail. I have now started to fit a bracket to the side of the pedal box to take the later press switch and run the 2 actuating wires inside the car.
May be worth considering while/if the pedal box is out.
PostPosted: Tue Jun 05, 2018 10:40 pm
+1 on the poor quality replacements. I bought a replacement hydraulic brake switch from my local "Auto One", lasted about 3 or 4 trips in the car and from memory cost about $30.
I'm thinking the same about fitting a mechanical switch.
PostPosted: Wed Jun 06, 2018 12:56 pm
I don't know if I've ever had an original fail, but I have a collection of them in my parts bin...
if you have the original, test it, if it works, use it
PostPosted: Wed Jun 06, 2018 1:26 pm
There's quite a good article about the widespread failure of the brake light switch here - http://mgaguru.com/mgtech/electric/et119a.htm
Clicking on the various hyperlinks in the article takes you to more detailed information. For example, this one shows what they look like inside - http://mgaguru.com/mgtech/electric/et119g3.htm
PostPosted: Wed Jun 06, 2018 5:23 pm
I see - it's an electrical failure rather than mechanical, I thought they might have collapsed internally or something.... they can't handle the current from the brake light globes... as he says in the first paragraph, chucking a relay in would fix it but I disagree with him that it'd add another point of failure.
PostPosted: Thu Jun 07, 2018 9:55 am
There are badly made relays out there too!
PostPosted: Thu Jun 07, 2018 11:24 am
I don't agree with a lot of what he says. If his list actually worked it would be a good thing, but the suppliers can't be depended on to continue putting the same part in the box.
If the relay keeps a cheap switch working then its a win, despite the added complexity.
I think I'd look at retrofitting a mechanical switch on the pedal, its what the factory did later on, and seems to be what the majority of modern manufacturers do. If it does fail, you don't have to bleed the brakes each time you replace it.
In the mean time, I'll carefully horde my small collection of old ones.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu Jun 07, 2018 1:36 pm
pretty sure the pressure switch was retained...
the mechanical switch was put there so the BRAKE FAIL warning light can work - if the mechanical switch is closed (pedal pressed) and the pressure switch is open (no pressure) then no brakes = warning light
PostPosted: Thu Jun 07, 2018 2:11 pm
The brake fail warning switch is built into the dual circuit master cylinder. In the UK they transitioned from the hydraulic switch to the switch on the pedal in 1976. It may have been a little later here.
The bracket to fit the switch to the pedal and the switch itself cost around $10.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Thu Jun 07, 2018 2:24 pm
I agree. I was hoping for a finite statement about where good new ones can be purchased but it seems to be a list of those that may or may not be faulty. The main reason I posted it was to show that others have recognised the same problem.
Genuine New Old Stock Lucas seems to be the safest solution, if they can be found.
PostPosted: Thu Jun 07, 2018 5:00 pm
Can't you find a good used one? I've never had one fail in 36 years and 6 Mini's. Current one is 51 years old..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 75 guests
