It is currently Mon Jul 14, 2025 9:55 pm
 Post subject: mini door light switches
PostPosted: Wed May 30, 2018 8:33 pm
Anyone know where you can buy these switches the metal type ?the ones that fit on the door pillar.
Allen
PostPosted: Wed May 30, 2018 8:49 pm
John Schmidt had these switches. There was a detail difference at the back for the electrical termination as they were also fitted to other models, but they are the same looking at the front of the switches.
PostPosted: Wed May 30, 2018 8:54 pm
https://minikingdomonline.com.au/produc ... ht-switch/
PostPosted: Thu May 31, 2018 10:29 pm
I've been told those straight switches may break when bending them to suit the Mini. Has anyone tried?
PostPosted: Thu May 31, 2018 11:40 pm
I didn't have a problem in my 69. I use two of them.
I believe that the hole was not always in the same position (further up the door frame) and this caused problems.
PostPosted: Fri Jun 01, 2018 3:38 am
I bent some years ago and had problems. So I fitted Rover switches.
OK OK it's not a Cooper S, but these have copper contacts so are a better switch. No bending required.
PostPosted: Fri Jun 01, 2018 10:55 am
I managed to pick up a pair from a seller on Trademe in NZ recently. Just checked with him and he does not have any more bent ones. He has some original straight ones but don't know if that's any better than what MKO have. I do have one spare that would clean up ok if that's of help to you.
Users browsing this forum: Phil 850 and 109 guests
