It is currently Tue Jul 15, 2025 3:55 am
 Post subject: Moke distributor
PostPosted: Sun May 27, 2018 6:51 pm
Today a Moke owner told me of an unusual problem. He reports that the distributor on his Moke is somehow catching and rotating, - with disastrous results. Ie. the whole distributor rotates (briefly!) and destroys itself. He started the engine today for me, and it was running but missing badly. He is afraid to run it because he suspects that the replacement unit will destroy itself too. Sorry I don't have more info, it seems weird to me. I could see nothing obvious wrong with the distributor. I'm wondering if anyone else has ever heard of this problem??
It sounds like the shaft bearing grabbing for some reason?
I don't know if different distributors were used on Mokes, the number is AKPPB1/102525
 Post subject: Re: Moke distributor
PostPosted: Sun May 27, 2018 7:13 pm
So has he pulled the dissy out and tried another one ? Most mini dissys will fit to get it to run , otherwise it'll be a deeper problem i would think .
PostPosted: Tue May 29, 2018 12:56 pm
"the whole distributor rotates (briefly!) and destroys itself" isn't really a useful description of the symptoms. It could be as simple as the clamp needs to be done up, or more sinister that the bush in the bottom has worn to the point where the whole shaft is binding, or all sorts of other things...
I'd suggest pulling the distributor out and turning it by hand with the cap off to see what it's doing....
PostPosted: Tue May 29, 2018 1:38 pm
A friend with an Austin 1800 had that happen to him when the spindle turned the distributor and stopped the car. He was a BMC mechanic and rebuilt the distributor. I can't remember if he modified it but he put it down to lack of lubrication.
PostPosted: Tue May 29, 2018 4:21 pm
araldite may fix it
PostPosted: Tue May 29, 2018 4:54 pm
Thanks to everyone for the responses. I will pass them on.
PostPosted: Tue May 29, 2018 5:43 pm
That happened many years ago on my Mk2 Austin 1800 ute, dissy just seemed to seize up suddenly and shut down the engine. Swapped in another dissy that worked ok.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Tue May 29, 2018 9:12 pm
You might find that at some stage in the distributor's life some one tightened the clamp too much and cracked or broke the base of the dizzy where the clamp tightens. 25D and 23 D distributors were known for this. Besy is to replace it and don't go crazy tightening the clamp.
<mod edit>
5. Advertising, spamming, and trolling is not allowed. This includes using the forum Private message system to spam other members.
</mod edit>
"Let us remove your "SHORTS"
Users browsing this forum: Bing [Bot] and 81 guests
