It is currently Tue Jul 15, 2025 3:57 am
PostPosted: Fri May 25, 2018 9:17 pm
Hi what brands are people using for timing chains and sprockets these days. Prefer adjustable
Thanks
Kiwiinwgtn
PostPosted: Fri May 25, 2018 10:34 pm
i have a MED vernier one. Nice bit of gear. Can't remember the brand of chain but seem to recall it being German.
PostPosted: Fri May 25, 2018 10:51 pm
Iwis chains seem to be highly regarded
PostPosted: Tue May 29, 2018 12:40 pm
I use the rollmaster adjustable set - cheap, adjusts to where the cam is meant to go, turns the cam
PostPosted: Tue May 29, 2018 8:02 pm
where can you purchase a rollmaster set. ta Kiwiinwgtn
Sent from my SM-J530Y using Tapatalk
PostPosted: Tue May 29, 2018 10:24 pm
just about anywhere... price for the same thing varies from :shock: to :wink:
http://minisport.com.au/mini-rollmaster ... d-sprocket
https://www.ebay.com.au/itm/BMC-Morris- ... .l4275.c10
seems like it comes with an IWIS chain...
PostPosted: Wed May 30, 2018 12:57 am
I found the rollmaster keyways confusing, I used an offset cam key instead.
PostPosted: Wed May 30, 2018 9:20 am
There is a nice How To on here for the rollmaster. I have used them a few times, good once you get your head around all the slots!!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Jun 01, 2018 8:49 pm
Rollmaster done my head in until I finally worked it out .They dont supply good enough instructions but they are a good set and are available for tunnel bored blocks.
