It is currently Tue Jul 15, 2025 4:42 am
 Post subject: Steering racks
PostPosted: Mon Apr 23, 2018 11:02 am
Hi guys, one for the brains trust.
I've got a '68 Deluxe, and was wondering, can we rebuild the existing Aussie steering rack with Swiftune rack/pinion/drumsticks?
"Made Exclusively for Swiftune this Competition Steering Rack has an increased ratio to enable 2.2 turns lock to lock. It fits in an early original steering rack body and accepts our heavy duty drumsticks"
Any help appreciated.
 Post subject: Re: Steering racks
PostPosted: Mon Apr 23, 2018 12:54 pm
I think the rack bar in the Aussie racks is larger, so it definitely wouldn't fit straight in. I assume the Swiftune stuff is designed for UK MK2+ steering geometry too, so the steering arms would have to be changed.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
PostPosted: Mon Apr 23, 2018 12:58 pm
In 1964 Australia changed to a Morris 1100 type steering rack, so I don't think those parts would be compatible.
viewtopic.php?f=2&t=96490
PostPosted: Mon Apr 23, 2018 1:14 pm
Unless you can find someone who can definitely say "I've done that" I would be very wary.
However, you could ask Swiftune what they mean by "......fits in an early original steering rack body...". All Mk Is??? Any particular year cut off???
Once they identify a particular UK Part #, you could check whether there are Oz supplied racks with the same part # . Otherwise you need someone with enough detailed knowledge to state that the Oz and UK racks use the exact/identical body
While there are other "quick racks" with reduced turns lock to lock IMHO the best option is the UK Mk II rack which takes about a metre out of the earlier UK (and all OZ) turning circle....
Cheers, Ian
PostPosted: Mon Apr 23, 2018 1:19 pm
Won't fit the later Oz made AEA6001 rack, they are 1/16" bigger diameter rack bar inside.
I have a few early racks, you can have one for nix if you want to play. But even these are completely different design on the rack bar ends to your pic.
PostPosted: Mon Apr 23, 2018 7:53 pm
yeah he can just use your early housing Doc & fit the swiftune shaft & swivel-spuds
PostPosted: Mon Apr 23, 2018 8:55 pm
Give that mana beer.
Doc, i’ll Be in touch. Swiftune owe me a favour.
PostPosted: Mon Apr 23, 2018 9:02 pm
My car has the early UK rack..
Are the UK MK1 racks and Aussie racks the same length? Do they use the same steering arms too?
PostPosted: Tue Apr 24, 2018 7:37 am
Early Oz minis used the mk1 UK rack and arms. It's the UK MK 2 on rack that had different shape arms and more rack teeth for a tighter turning circle.
Many people here using Oz arms and UK MK 2 on rack, doesn't seem to cause major problems.
Note all Oz arms are MK 1 type but there are thin, and later thick.
Edit
You can tell these mk2+ UK arms, they have 2 little ears at the end.
Users browsing this forum: Bing [Bot] and 83 guests
