It is currently Tue Jul 15, 2025 4:34 pm
 Post subject: Re: Baulk rings
PostPosted: Thu Apr 12, 2018 5:20 pm
Even the new competition baulk rings, don't seem to last long. Is the baulk ring metal too soft and wears quickly. Is the profile of the cut too aggressive , and so works well but wears out quickly? Is the gear coating causing the difference? Is 100 HP per litre of engine too much power to control? All theories welcomed. A vexing and disappointing issue.
PostPosted: Thu Apr 12, 2018 7:03 pm
Karcraft I think posted some manufacturing information a while back.
If I recall, up until about 1969 they were forged steel, the flycuts on the outside are caused by milling of the tapered lugs.
After this time they started using sintered powder metallurgy, and these were good at the time.
My thoughts...
With the demise of Rover production there is great variability in Quality of what we get now. I don't know if it's material, production method, poor machining or what.
Note that the 3 lugs are designed to be hard and the rest left much softer, perhaps this makes keeping them round a challenge.
ps. I was a production engineer in a previous life. ;)
PostPosted: Thu Apr 12, 2018 8:45 pm
Correctly identified!!
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Apr 15, 2018 9:50 am
You can extend life of good (not yet worn out) older baulk rings by surface grinding .020" off the face that goes toward the gear. However eventually you run out of good ones and have to buy new from somewhere. As I said in my post above, check the fit of what you are buying. Some are better than others.
If they don't fit right, don't buy them.
How is surface gringing achieved? Do I just rub the face of the ring course wet stone or is it more technical?
PostPosted: Sun Apr 15, 2018 12:06 pm
You can do them on a surface grinding machine if you have one. I don't, I use the flat plate on my bench grinder belt sanding attachment. And use a micrometer to check they stay flat.
The lugs are too hard to file, or machine.
PostPosted: Thu Apr 19, 2018 7:28 am
is there any mileage in adding extra crosscuts to the 6 cut ring?
Users browsing this forum: belldane and 88 guests
