It is currently Tue Jul 15, 2025 10:01 am
PostPosted: Fri Mar 30, 2018 8:37 pm
As above, should the reinforcements face the radiator or the engine ?
PostPosted: Fri Mar 30, 2018 9:33 pm
PostPosted: Sat Mar 31, 2018 11:29 am
Does the steel fan give better cooling than the plastic fan.
PostPosted: Sat Mar 31, 2018 4:41 pm
I believe so. They don't toss blades off either.
And if they get bent, can be straightened.
PostPosted: Sun Apr 01, 2018 10:44 am
Yes they do, but they are the noisiest fan available.......
PostPosted: Sun Apr 01, 2018 12:17 pm
I tried both it and the yellow plastic one. The plastic was way noisier. So I went back to the mk1 16 blade metal one.
Isn't the tropical 4 or 6 blade supposed to be the noisy one?
PostPosted: Sun Apr 01, 2018 1:20 pm
Yes the four blade is very noisy as well! but the 16 blade makes a whiny noise that just grates on me..........
