It is currently Tue Jul 15, 2025 9:21 am
 Post subject: Front mounted radiator
PostPosted: Thu Mar 22, 2018 5:22 pm
Has anyone mounted an MPI front radiator in an Australian mini?
PostPosted: Thu Mar 22, 2018 6:34 pm
The MPI didn’t have a distributor and they had moved the oil filter and alternator by that stage to clear. You might find it really tricky to access the oil filter and I think you’d have to get an aftermarket trigger wheel style ignition?
There is a good guide to MPI changes here
http://www.roblightbody.com/1998---exam ... m-spi.html
PostPosted: Thu Mar 22, 2018 6:51 pm
You could use a remote oil filter bolted on the inner guard
PostPosted: Thu Mar 22, 2018 9:54 pm
I think I might just run the standard radiator. I've read that the later English minis had the engines moved forward in the engine bay and thought that there may be more room at the front of the Aussie mini.
PostPosted: Thu Mar 22, 2018 10:24 pm
I've seen a front mount rad in a Clubman, it was a scrap yard part so I can't tell you what it was out of but it was alloy core with plastic end tanks and a thermo fan bolted straight to it.
PostPosted: Fri Mar 23, 2018 7:27 am
VW polo
PostPosted: Fri Mar 23, 2018 8:04 am
I've used an Alfa 33 radiator/thermo setup in a Clubby.
Users browsing this forum: 1071 S and 80 guests
