It is currently Tue Jul 15, 2025 1:02 pm
PostPosted: Thu Mar 22, 2018 6:05 pm
As per title would have a the standard height of a cylinder block. I have one in good condition but it looks to have had a couple of mill shaved off the top. Looking to hopefully use it to build a stroker engine. May need to get the piston dish machined to reduce the compression ratio so I can use it.
Ta Kiwiinwgtn
PostPosted: Thu Mar 22, 2018 7:53 pm
I will measure one in the morning.
Re the pistons, hypatecs are good for strokers as the rings are lower than most others, allowing more to be machined off the top. I reshaped the dish similar to GR's ones.
PostPosted: Fri Mar 23, 2018 4:52 pm
227mm measured with a new Stanley tape.
Standard block still has bore size stampings on.
PostPosted: Sat Mar 24, 2018 5:10 pm
My stroker has hypatecs done by GR There is 10cc in each piston dish
PostPosted: Fri May 04, 2018 6:19 pm
thanks for the replys
Sent from my SM-J530Y using Tapatalk
Users browsing this forum: ken@miniauto and 90 guests
