It is currently Thu Jul 17, 2025 12:23 pm
 Post subject: Dolly / Trolley
PostPosted: Mon Mar 19, 2018 8:35 pm
Hi All,
I’m a tall bloke and am finding working on the mini on jack stands tiresome so I want to build a dolly to put the mini k she’ll on for resto.
I know how it can be annoying to post a topic that has already been covered before but I have searched the site and can’t find anything.
Just wondering if anyone has made a dolly for their resto and what size wall thickness on the steel box they used?
Bman
Zulu...
1967 mini Cooper S
 Post subject: Re: Dolly / Trolley
PostPosted: Mon Mar 19, 2018 9:31 pm
If you can get an old hospital bed mine sat on one of those with the engine and subframes for quite a while, they are very strong and height adjustable within a limited range, if there's some going you probably won't find a cheaper or easier way to do it.
Roads need more corners
PostPosted: Tue Mar 20, 2018 10:13 am
Thanks fuzzy hair man
Zulu...
1967 mini Cooper S
PostPosted: Tue Mar 20, 2018 7:04 pm
Massively over engineered, but may be available soon!
PostPosted: Wed Mar 21, 2018 5:29 pm
That’s what I’m talking about!!!
Are those uprights bolted into existing captive nuts in the floor pan?? Both front and rear?
Bman
Zulu...
1967 mini Cooper S
PostPosted: Wed Mar 21, 2018 6:40 pm
Bman
Yes - seemed like the easiest way to secure it
PostPosted: Wed Mar 21, 2018 10:09 pm
I know some people have used pallets with caster wheels as a cheap dolly. If you want it higher just stack more pallets on it.
I made a square frame to sit under the floor pan with hight adjustable legs (like a jack stand) with castor wheels on the bottoms. The open square frame was so I could still access the floor pan.
PostPosted: Thu Mar 22, 2018 8:31 am
We did the same as Kenno but with fixed legs. 4 swivel castors.
PostPosted: Thu Mar 22, 2018 5:05 pm
I made a wooden one
Not as much under-car access as I didn't lift it off the ground like the metal ones posted here.
Shell's about to be put on a spit, yo.
PostPosted: Thu Mar 22, 2018 9:10 pm
Nice one Morbo
Zulu...
1967 mini Cooper S
