It is currently Wed Jul 16, 2025 2:58 am
 Post subject: Power options
PostPosted: Sat Mar 17, 2018 10:25 pm
Ok dudes and dudettes,
I have a complete 1275 that I want to make mental and put in a mini k. I’m thinking turbo or supercharger. So, NA? Turbo? Or supercharged?
Bman
Zulu...
1967 mini Cooper S
 Post subject: Re: Power options
PostPosted: Sat Mar 17, 2018 11:59 pm
Supercharge with the 40 or 45 dcoe vmacscart kit. Keen to see how they go
PostPosted: Sun Mar 18, 2018 6:40 am
Why choose? Put both on . :-)
PostPosted: Sun Mar 18, 2018 7:02 am
A sc kit would be reasonably easy to do and would go quite well but I would go turbo. Would be a sqeeze, may need to mod the bulk head though.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Sun Mar 18, 2018 7:29 am
I hear SC12 parts are getting scarce.
Re a turbo, you can get kits now that fit it above the firewall, no cutting needed. Contact 'benjamin' on here.
PostPosted: Sun Mar 18, 2018 8:30 am
7 port or BMW bike head with a turbo
still too many compromises - fueling before the blower that is too small and no charge cooling - can never make any real power
PostPosted: Sun Mar 18, 2018 8:39 am
I think the best bang for your buck will be a turbo if you can do the work yourself.
The supercharger kits are an easy option as you can buy the kits with most of the hard work done already.
Do you have a current power goal in mind and what kind of spec is the 1275 engine now?
PostPosted: Sun Mar 18, 2018 9:08 pm
Really the sky is the limit when it comes to mods but these days it's all about turbos. A well suited snail for your custom built engine will be better than a sc of the same built style.
Also pump E85 is getting more common which means higher comp ratios = MAX POWER :twisted:
Users browsing this forum: No registered users and 66 guests
