It is currently Sat Jun 28, 2025 12:25 am
PostPosted: Sat Mar 10, 2018 10:53 am
Hi All
I was going to fit a new electronic su fuel pump AUF214EN and was wondering if someone could tell me what the lug next to the power terminal is used for? There is another one lower down.
PostPosted: Sat Mar 10, 2018 12:15 pm
Tomtax wrote:
Hi All
To cater for either a ring terminal, or a Lucar style connector, depending on the termination on the wiring?
PostPosted: Sat Mar 10, 2018 12:43 pm
DavidE wrote:
Tomtax wrote:
Hi All
Are you referring to the breathers?
There are 2 breathers on the fuel pump you have. One goes to the cabin. The other check valve is open to atmosphere .
PostPosted: Sat Mar 10, 2018 1:05 pm
Hi Gto
Yes I was referring to the breathers.
So at present I don’t have a pipe to connect F to B in the diagram you have provided so will it be ok to fit it without the pipe? I won’t be able to get a pipe till Tuesday and I don’t trust my rather noisy current pump
Thanks again
PostPosted: Sat Mar 10, 2018 1:16 pm
Tomtax wrote:
Hi Gto
Thanks again
The bit then is definitely not a "lug".
PostPosted: Sat Mar 10, 2018 1:39 pm
Tomtax wrote:
Hi Gto
Thanks again
Yes you can run the pump with the diaphragm breather open to the elements for a short while. They are only there to allow air in and out as the fuel pump diaphragm moves back and forth. A few weeks or months will be fine as long as your not doing any bush bashing.
PostPosted: Sat Mar 10, 2018 5:32 pm
The so called lug next to the 12V connector is a one way exhaust/check valve that allows air drawn in by the diaphragm, via the plastic tube that goes to the interior under the rear seat, to exhaust as the diaphragm moves back and forth.
When the diaphragm draws in air from the interior the exhaust/check valve closes (there is a small ball inside the valve).
When the diaphragm moves back the air is exhausted through the one way valve. This ensures there is always air flow around the points on the original point type setup.
Is this needed for the pointless electronic version? I don't know but it does provide some cooling for the electronics.
RonR
68 build Mk1 Cooper S
PostPosted: Tue Oct 04, 2022 6:07 pm
I am confused. Are there 2 breather holes in the SU AUF214EN fuel pump. Does one go the cabin but where does the second go?
PostPosted: Tue Oct 04, 2022 6:38 pm
The breather inlet comes from the cabin via the tube. The outlet is open to atmosphere via a check valve.
The outlet check valve used to look like this.
PostPosted: Fri Oct 07, 2022 8:59 am
I have just spent $300 on an AUF214EN SU pump and there are no intructions.
I bought this because the Facet pump that came with my Cooper S appears useless giving fuel to the carbies only when the tank is full. I figure it's because the pump can't suck, it can only push.
Hope you guys can help. Please see questions I have posed in the pictures.
PostPosted: Fri Oct 07, 2022 12:56 pm
Yes
Yes
No where
Yes
