It is currently Sun Jun 22, 2025 8:47 am
 Post subject: Machine Shop Brisbane
PostPosted: Fri Feb 23, 2018 8:31 pm
Can anyone recommend a machine shop is Brisbane that knows about Mini engines ?
Will need a crank grind, block bore and some balance work, I am sure pretty much any company should be able to do it, but someone who does a nice job and knows Minis is always good.
Thanks
Stewart.
PostPosted: Fri Feb 23, 2018 8:42 pm
Try Matt Read in Murrarie. He is a lovely bloke and contributes a lot on here. He will be able to sort you out, even if he does not machine in house per se.
ReadSpeed Mini Mecca & The Mini Man
Shed 5L, 167 East,
Murarrie Road,
MURARRIE, QLD, 4172
Tel: (07) 3399 9999
Mob: 0407 135 656
Try and find other Mini businesses here
PostPosted: Fri Feb 23, 2018 10:46 pm
Wynnum Engine Reconditioning
25 Thorne St, Wynnum QLD 4178
(07) 3893 1164
I have found them very good, excellent quality workmanship. They have machined Mini engine parts for me for a number of years. I know Matt Read uses and recommends them, but I'll let Matt speak for himself.
They completed a Mini 1275 crank grind and engine bore for me last week.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sun Feb 25, 2018 8:52 pm
Thanks for the replies guys.
Much appreciated.
Stewart.
PostPosted: Mon Mar 05, 2018 12:50 pm
Chilton Engineering,
6 Deshon Street,
Woolloongabba
Ph: 3391 1672
PostPosted: Thu Mar 08, 2018 4:15 am
I also recommend
6 Deshon Street,
Woolloongabba
Ph: 3391 1672
David is an ex mini cooper owner and racer and has a very good knowledge of minis and is well known for his engine work.
