It is currently Tue Jul 15, 2025 11:21 pm
 Post subject: Stubborn fuel tank
PostPosted: Tue Mar 06, 2018 8:29 pm
Hey All,
Tried to get the fuel tank out tonight but it’s being stubborn. The strap is undone, fuel line removed, cap off and fuel filler cap rubber off but it won’t come out. It appears to be stuck on what seems to be the fuel drain pipe which is running through a hole in the boot floor (see pics). Any tips on how to remove it??
Brendon
Zulu...
1967 mini Cooper S
 Post subject: Re: Stubborn fuel tank
PostPosted: Tue Mar 06, 2018 8:30 pm
Zulu...
1967 mini Cooper S
PostPosted: Tue Mar 06, 2018 8:33 pm
Mine was cut off shorter, you can get a tube socket/spanner long enough to get it undone so you can remove the tank.
PostPosted: Tue Mar 06, 2018 8:57 pm
I use a piece of 1/2" square section inside a standard socket.
PostPosted: Wed Mar 07, 2018 4:57 am
zulu_warrior1976 wrote:
Hey All,
Brendon
I have a right size nut driver with a hollow shaft long enough to reach the nut on the drain tube. It works a treat.
PostPosted: Wed Mar 07, 2018 7:31 am
Thanks all. Will let you know how I get on tonight.
Brendon
Zulu...
1967 mini Cooper S
PostPosted: Wed Mar 07, 2018 8:08 am
Tube spanner is required.
PostPosted: Wed Mar 07, 2018 8:27 am
or shorten the drain tube like a lot of others do :!:
PostPosted: Wed Mar 07, 2018 8:32 am
It's a PITA.
Just plug the damned thing with a 3/8" UNF grubscrew. RH tank has no drain, why should the LH one need one? Siphon the tank if you need to drain it. ;)
PostPosted: Thu Mar 08, 2018 12:24 pm
Problem solvered!!!! After a tough time getting a spanner into the nut it loosened and I was fortunately able to unscrew it by finger spanner! It’s out. Many thanks for your words of wisdom.
Onto the next problem now which is trying to undo the rear nut on the bottom door hinge that abuts the bulkhead. Aaaarrrrrgh!
Can get a socket on it but can’t get the socket driver into the socket once it’s on the nut.
Can get a ring spanner on it but don’t have enough room to turn it!
There must be an easier way!
Zulu...
1967 mini Cooper S
PostPosted: Thu Mar 08, 2018 1:57 pm
I use one of these for the rear hinge nut
http://www.supercheapauto.com.au/Produc ... ive/221226
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Thu Mar 08, 2018 5:19 pm
I just use a good quality 1/4 drive socket set with universal. No worries with that.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Mar 09, 2018 7:00 am
Small ratchet ring spanner :?:
PostPosted: Fri Mar 09, 2018 9:45 am
Mick,
You won't fit that ratchet ringy in because of the hinge bracket flanges and the wheel well. Buy a cheap ring/OE spanner and grind the ring end as thin as you dare. :)
PostPosted: Sat Mar 10, 2018 11:56 am
Mick,
Yep Doc...or same, same for a tiny ratchet...
Users browsing this forum: Barkfast and 95 guests
