I run the RE282 and 1.5 rockers in my 1360, and it's been great.
My 1412 stroker had an RE13 and 1.4 Corolla rockers, it went hard, made 112 ft/lb of torque with a single HS6 on Graham's manifold.
But I reckon the RE282 would be even better in that big a motor.
My 1411 has the RE282 and standard rockers to make 114 ft/lb. But also has more than 100 ft/lb all the way from 2000rpm to 7000rpm (from memory - for exact figures see my dyno post on here somewhere). Sticking 1.5:1 rockers will shift that up in the rev range for more power but unlikely to to see increase in max torque.
GR has a newer cam with similar specs (the RE282 master was lost - Kev's (drminiin aust), mine and the one fitted to willy's motor that he sold remain), but he reckons even more betterer down low. Don't recall the number - he will be able to advise directly.
michael
66 Mini Minor sponsored by
http://www.lifeonthehedge.com.au/ The Dog Harness Specialists
It was a pleasure ausmini. I'll miss all you misfits and reprobates
