It is currently Wed Jul 16, 2025 7:36 am
 Post subject: Nuts and bolts
PostPosted: Tue Feb 27, 2018 11:52 am
Well, started stripping the engine bay on the K and Lo and behold I hit some challenging nuts on the brake and clutch reservoirs. I was using an extension on the socket set, got too much leverage and snapped 3 of 4 off.
Should I just drill them out and fit some bolts through before I get it sandblasted, primed and painted?
Zulu...
1967 mini Cooper S
 Post subject: Re: Nuts and bolts
PostPosted: Tue Feb 27, 2018 11:53 am
Zulu...
1967 mini Cooper S
PostPosted: Tue Feb 27, 2018 12:01 pm
Those 4 "bolts" are part of the pedal box and should come when you remove it. You can then replace them.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Tue Feb 27, 2018 4:39 pm
Thanks cgo
Zulu...
1967 mini Cooper S
PostPosted: Tue Feb 27, 2018 6:55 pm
Zulu,
You'll have to cut off the broken studs, drill out what's left and weld in suitable new bolts.
Clive
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1982 RX-7 Series 2
PostPosted: Tue Feb 27, 2018 8:05 pm
I did mine recently... be careful to locate them properly, there isn't a lot of wiggle room in the holes in the crossmember
PostPosted: Tue Feb 27, 2018 9:23 pm
Hi ZuluWarrior1976
I have a couple of spare pedal boxes with the bolts still attached-you can have one if you want to pick it up :D
I'm in South Plympton SA.
Dave
"64 Smooth Roof Van (Colin)
PostPosted: Wed Feb 28, 2018 9:42 am
Once you've removed the old studs, I'd consider dummy assembly with bolts in place through pedal box and bulkhead and tack weld the bolts in while assembled so you're sure they are correct. You'd have to check to see if there's enough room to stick a wording torch up there though.
PostPosted: Wed Feb 28, 2018 10:19 am
Once the damaged bolts are removed and new ones put in place before welding, could you use the blanking plate from the other side where the heater hoses pass through the box section. They have the same bolt pattern with or without the holes for hoses.
That way you can weld off the car.
PostPosted: Wed Feb 28, 2018 10:30 am
Why don't you take up CaptainWaldoPepper's kind offer?! It will save you loads of hassle and you'll get to meet a new Mini friend.
It's a no brainer! :-)
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Wed Feb 28, 2018 6:41 pm
ditto!
PostPosted: Wed Feb 28, 2018 7:19 pm
:c)
Zulu...
1967 mini Cooper S
