It is currently Tue Jul 15, 2025 8:07 am
 Post subject: DAM6027 Diff cage
PostPosted: Wed Mar 23, 2011 9:39 am
Hi
Am wanting to see the inside of one of these diff cages, does anyone have a picture that they can post as the only pics found on a google search only show the outside.
steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Mar 23, 2011 10:44 am
Is that the A+ cage you want to see Steve?
Dave
PostPosted: Wed Mar 23, 2011 10:59 am
Dave
Yes that's the one, do you have a pic of it :?:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Mar 23, 2011 11:23 am
Mods rock!
I do have few here, I'll see if I can dig one out for a pic.
The only really difference between this one and the early one is that it has slots cut in to it for the sun gear thrust washers (these have 'ears' on them). It would be easy to modify an early one for the same.
PostPosted: Wed Mar 23, 2011 11:30 am
Hi GT, that would be good if you could get a pic for me. The difference that you explained is exactly what I want to see.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Mar 23, 2011 2:04 pm
i have some here if you want to look at one Steve
PostPosted: Wed Mar 23, 2011 7:07 pm
Mods rock!
(Can never find something simple.............)
Steve, they are similar to these, only two notches instead of four
PostPosted: Wed Mar 23, 2011 7:25 pm
Thanks Gt, that's just what was needed.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Wed Mar 23, 2011 7:30 pm
Mods rock!
Steve
Your welcome :wink:
 Post subject: Re: DAM6027 Diff cage
PostPosted: Tue Feb 27, 2018 6:46 am
Has anyone used this diff cage on there car and if so are they compatible with the contents of the original 1969 Mk2 Cooper S diff case except the bronze sun gear bushes?
PostPosted: Tue Feb 27, 2018 7:01 am
Yes they are exactly the same inside except for 2 slots for the ears. You can fit early thrust washers instead but then they will spin in the case and wear it. Why they fitted the ears....
If your diff has the original bronze side gear washers keep them. The fibre ones sold now are generally too thick and don't last like the bronze ones do.
PostPosted: Tue Feb 27, 2018 7:19 am
From what you said I guess the bronze side bushes are not available any more?
PostPosted: Tue Feb 27, 2018 7:40 am
NLA unless you find some S/H ones. Matt Read or John Smidt may have some.
PostPosted: Tue Mar 27, 2018 5:05 pm
Has anyone modified the standard diff case BTA145 to accept DAM5071 if so did it work out and how was it modified.
PostPosted: Tue Mar 27, 2018 9:50 pm
I have done quite a few over the years, it's just 5 minutes work with a die grinder or a bit longer with files.
It works fine. Stops the copper washers from wearing the diff case. But pick a case that isn't worn bad to start with, check around the pin hole for a raised lip (= worn).
