It is currently Tue Jul 15, 2025 12:38 pm
PostPosted: Tue Feb 20, 2018 7:20 pm
Hi everyone,
Can any body remember who was selling the complete preformed oil pressure guage pipe, reinforced rubber hose & clamps on e bay recently? - I was watching the item for months when I didn't need it, but now that I do, I can't find it any more.
I reckon it was "minimakeovers" or some one like that.
Thanks in advance,
Ian.
PostPosted: Tue Feb 20, 2018 8:46 pm
Pretty sure I've got one somewhere.
PostPosted: Wed Feb 21, 2018 8:36 pm
Here
https://www.ebay.co.uk/itm/Mini-Oil-Pre ... SwVL1WDj~1
PostPosted: Fri Feb 23, 2018 6:01 am
How come you need one Ian , is it because yours is damaged or broken ?
Reason i ask is i snapped the pipe at the "P"clamp on the side of the block once and repaired it by cutting a piece of brake pipe and sleeving it over the pipe and soldering it :idea: .
You don't see them popping up for sale too often .
PostPosted: Fri Feb 23, 2018 6:33 am
You can still buy them new. Not cheap and the hose is cheapo compared to the original. Its only 7mm and the $10 ea clamps hardly hold it.
I bought a hose and clamps recently.
The original hose was similar to a Mini hydraulic brake hose. Much thicker.
PostPosted: Fri Feb 23, 2018 2:11 pm
I remember seeing it for over 12 months on ebay. Now you need it the listing is gone. Good luck with the search. I will keep an eye out.
PostPosted: Wed Mar 07, 2018 8:50 am
I bought some 1/8" USA made fuel vent hose today, it is much thicker and reinforced.
At $5 a metre it's heaps cheaper too. And over 8mm thick so will clamp better. :)
Can't use brake hose, its allergic to motor oil the brake shop says.
PostPosted: Thu Mar 08, 2018 10:47 am
For the metal pipe, I remade one with the old ends soldered on, but using copper tubing, which is fairly soft and easily damaged. I think the original was made from steel tubing, but it I couldn't find any in that diameter.
PostPosted: Thu Mar 08, 2018 2:52 pm
Pretty sure they are copper
PostPosted: Thu Mar 08, 2018 9:34 pm
Actually, I believe it was copper plated steel tubing.
PostPosted: Thu Mar 08, 2018 10:16 pm
I'll try rubbing the spare I have with emery paper just to see.
PostPosted: Fri Mar 09, 2018 5:42 am
This one looks like steel to me.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Thu Mar 22, 2018 5:39 pm
You could always try a magnet. To be 100% sure.
PostPosted: Fri Mar 23, 2018 6:59 pm
The pipe is originally steel
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 26, 2018 1:51 pm
https://www.minispares.com/product/classic/CAM4202.aspx
I bought this one as well as the hose, clamps and pipe to gauge
------------1967 Mini Cooper S--------------
The quality will be long remembered well and truely after the price is forgotten.
Users browsing this forum: ken@miniauto and 86 guests
