It is currently Wed Jul 16, 2025 4:58 am
PostPosted: Sat Feb 17, 2018 1:08 pm
How does one remove this bearing without wrecking it like I have.
PostPosted: Sat Feb 17, 2018 1:37 pm
I would assume use a suitable puller, its a need roller yes?
PostPosted: Sat Feb 17, 2018 2:17 pm
I have a little 3 leg puller I use - I think I had to grind the feet a little thinner to get between the ring and the nut, but that's the way I do it...
PostPosted: Sat Feb 17, 2018 2:18 pm
It was until I broke the cage and the needles dropped out.
PostPosted: Sat Feb 17, 2018 2:22 pm
I made one of these from a piece of 50mm square tube.
PostPosted: Sat Feb 17, 2018 2:23 pm
Have used a small 2 jaw puller.
Or read this;
http://www.ausmini.com/forums/viewtopic.php?f=25&t=66729
Sorry, too late.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Sat Feb 17, 2018 8:27 pm
Removing the bearing from the shaft is easy. Removing the outer shell from the transmission casing is much more fun (which you will now need to do since you've totalled the inner part! :evil:
PostPosted: Sat Feb 17, 2018 8:41 pm
Thanks for your guys.
PostPosted: Sun Feb 18, 2018 6:55 am
Easy. Just run a weld around inside of shell, it'll just fall out......into the trash.
PostPosted: Fri Feb 23, 2018 5:51 pm
Or read this;
Sorry, too late.
Nice to see my link in use,
Pitty about photobucket issues
