It is currently Wed Jul 16, 2025 4:30 am
Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2, 3  Next
 Post subject: Hydro fluid
PostPosted: Sat Feb 17, 2018 2:36 am
Hi guys. I managed to find a 20 litre drum full of this fluid. Does anybody know much about it or used it. Is it good, bad, or the ducks nuts....Image
Sent from my SM-G955F using Tapatalk
1965 Smooth roof Van
1969 Cooper S MK2
1970 Mini K
 Post subject: Re: Hydro fluid
PostPosted: Sat Feb 17, 2018 10:31 am
Yes. That is good. I have been using it for a long time. I would suspect it is commonly sold and used in Australia. I bought from the factory at the address on the tin. The owner told me his father worked for H.C. Sleigh who originally made it for BMC Aust. and this was as close as possible to the original formula.
PostPosted: Sat Feb 17, 2018 12:21 pm
Well that is good news. Thankyou.
1969 Cooper S MK2
1970 Mini K
PostPosted: Sat Feb 17, 2018 12:36 pm
Specially formulated? Wow, must really hard to make a batch of 50/50 IPA (isopropyl alcohol) and water! Pretty sure its IPA, I'm a petroleum chemist and used it loads of times, has a distinctive smell. Can probably buy 20L drums of the stuff really cheap, it's a bog standard industrial solvent...
Edit: I stand corrected. The stuff is apparently 49% alcohol, 49% water, the remainder being a "lubricant" and corrosion inhibitor.
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Feb 17, 2018 1:02 pm
They still sell it, I bought some last month.
PostPosted: Sat Feb 17, 2018 2:21 pm
they sell it at autobarn, repco and supercheap too, it's called 'antifreeze'
PostPosted: Sat Feb 17, 2018 4:52 pm
Methanol is what i use when making a brew
1970 MK2 Cooper S
PostPosted: Sat Feb 17, 2018 6:50 pm
What does 20L Cost?
PostPosted: Sun Feb 18, 2018 11:02 am
Some information about various versions of hydrolastic fluid on sale. Tony Cripps is a member of the BMC-Leyland Heritage Group.
http://www.amvcnsw.com.au/austin1800/WS ... 0fluid.pdf
PostPosted: Sun Feb 18, 2018 3:50 pm
He left out MKO as a local supplier - https://minikingdomonline.com.au/produc ... l-formula/
Here's a few threads about hydro fluid. In the first one I posted some of the BMC documentation mentioned by Tony Cripps.
http://www.ausmini.com/forums/viewtopic.php?f=2&t=88452
http://www.ausmini.com/forums/viewtopic.php?f=2&t=96145
PostPosted: Sun Feb 18, 2018 4:26 pm
They use alcohol as it forms an azeotrope with water and prevents corrosion. :P
PostPosted: Mon Feb 19, 2018 6:50 am
I have used ethylene glycol/deionised water 50:50. Commonly used in USA.
PostPosted: Mon Feb 19, 2018 12:59 pm
That'd do it Doc I reckon. The corrosion inhibitor in the coolant will do the trick...
Out of curiosity, what volume of the stuff is required?
Note: If you really got stuck you could just use water as a temporary solution. It's a fluid therefore non compressible, probably change the suspension characteristics somewhat however?
67 Deluxe
Dry suspension
PostPosted: Mon Feb 19, 2018 1:50 pm
I think Simon K uses straight glycol concentrate as it's a bit thicker and damps better.
I reckon a litre each side, mix 4L up and you will have half it left after pump up, let down fast, and pump up again.
PostPosted: Mon Feb 19, 2018 2:54 pm
Is that all? Only a couple of litres?!
I wonder how viscosity sensitive the system is? Seems not much, there'd be a fair difference in viscosity between an alcohol/ water brew and straight ethylene glycol I imagine. (could try and look it up, surely there is a viscosity spec somewhere). I imagine the key to whatever you use is having a corrosion inhibitor...
67 Deluxe
Dry suspension
