It is currently Fri Aug 22, 2025 12:35 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 555, 556, 557, 558, 559, 560, 561 ... 568  Next
PostPosted: Wed Jan 31, 2018 9:36 pm
Very nice 8)
Is that pearl on the roof ?
PostPosted: Thu Feb 01, 2018 4:02 am
Phil 850 wrote:
Very nice 8)
Just a little pearl to match the Mica in the red, otherwise the roof looks a bit flat.
PostPosted: Thu Feb 01, 2018 6:09 pm
Came home to a bunch of goodies for the Mk2 resto! :mrgreen:
Full Mk2 S sticker kit.
Full set of 5x LP883's.
PostPosted: Sun Feb 25, 2018 1:14 pm
got it in the garage and on to the trickle charger.
Upcoming - oil and brake/clutch fluid change.
Otherwise still as good as the day it went on holidays!
PostPosted: Sun Feb 25, 2018 1:47 pm
Turned my 12ft tinny's boat trailer into a Mini boat trailer.
It now sports a pair of KYB Mini front shocks. :) No more bouncing...
PostPosted: Sun Feb 25, 2018 2:26 pm
Installed new pistons in block. Just taking my time. Project is one huge jigsaw puzzle, finding the correct bits searching though many different containers, is a challenge.
Clive G
1969 Mk II Cooper S
1970 MK II Cooper S
1963 Triumph Spitfire
1982 RX-7 Series 2
PostPosted: Thu Jun 07, 2018 2:30 pm
Added a bit of bling under the bonnet 8)
PostPosted: Thu Jun 07, 2018 3:32 pm
Is that going into a Jet red MK2 S?
PostPosted: Fri Jun 08, 2018 8:54 pm
Nice clive ! I have your puller to return . Will be taking my bits into wynnum for maching soon too :)
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Sun Jun 10, 2018 9:17 am
Into the spray booth yesterday
PostPosted: Wed Jun 27, 2018 4:31 pm
Tubbed the rear on the 67 Deluxe. Ready for 13's. And yes 13's do look the best. :shock:
(I have had 10 x 4's, 10 x 5's, 12 x 5's and 13 x 7' in the past)
For a Cooper S you would want to stay with the stock 10's but I am sick of people telling me how terrible 13's are on a mini (Tram lining, early bearing failure, poor handling) all rubbish.
Only downside that I have experienced is the steering is a little heavier. As for handling, bugger all difference. Lets face it, these cars are not really quick enough to push the limits of any of the wheel and tyre options if set up property. Each to their own though!
1310 SC 1969 Morris Deluxe - 15psi boost
1293 1968 Morris Deluxe Miglia - 45 Weber
HSV Maloo Z Series - Comp Cam - 300rwkw
Ford DF LTD - 5Ltr
PostPosted: Wed Aug 15, 2018 8:03 pm
Bought new mirrors (already in transit, way to go minisport) and ordered a new set of Yokohamas to fit to my new purchase (73 Panelvan coming home very soon).
Argued with the wife as to why i get to buy a running registered mini for me while hers is still in pieces.
Looked at more parts and found some self control (for now).
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Mon Aug 27, 2018 10:37 pm
Most of the dynamat installed.
Dynaliner roof insulation is in.
Rear wiring harness installed too.ImageImage
Sent from my SM-G950F using Tapatalk
You can't drive your shares on the weekend...
PostPosted: Tue Aug 28, 2018 8:02 am
I have been running 36mm chokes in my 45 Dellorto since before fitting the Accuspark black box 3? years ago. Because everybody said these are best.
But just for fun I refitted the 38 chokes 2 weeks ago and found it goes much harder.
36 might work best in a Weber, but not in this. It has torque steer in lower gears now. :mrgreen:
Note it's got a race head and big ported manifold.
PostPosted: Tue Aug 28, 2018 5:30 pm
Finally removed my engine from my Mk 2 S and stripped it down for inspection.
Forgot to drain the sump-now have old oil all over the floor!
This is the motor I "ran in" years ago using GTX oil. That was a costly mistake!
