It is currently Wed Jul 16, 2025 10:04 pm
 Post subject: Re: Running temp.
PostPosted: Sun Jan 28, 2018 3:36 pm
ricksmini wrote:
So I bought a infrared themometer. Changed the earth position on the voltage regulator. Tested both the gauge now reads 10-15 degrees warmer then the thermometer. Will speak with my auto elecy tomorrow
and get him to fit one of these :idea:
https://www.ebay.co.uk/itm/Smiths-30-11 ... xyeZNTQs32
PostPosted: Sun Jan 28, 2018 6:02 pm
So does anyone actually have any hard evidence as to what a Mini engine should actually run at ... "normal" not racing conditions..
ie what actual water temps = "N"??
And what voltage (Mk I/12 V system) is the equivalent of a "normal (N)" and hot (H) gauge readings????
Cheers, Ian
PostPosted: Sun Jan 28, 2018 6:30 pm
Been done to death...should be a sticky...
viewtopic.php?f=2&t=70236&hilit=temperature+sender+resistance
PostPosted: Sun Jan 28, 2018 7:17 pm
In case it helps, the BMC engineering drawing for the Smiths temp gauge used in the MK II Series Minis (part AYA9168) says:
"52 degrees C at the Cold position and 120 degrees C at the Hot position".
PostPosted: Sun Jan 28, 2018 7:43 pm
It would probably be around the temperature of the standard thermostat.
PostPosted: Mon Jan 29, 2018 6:41 am
So...N = about 85C
PostPosted: Mon Jan 29, 2018 8:00 am
Mine runs about 82C with an 82C thermostat, needle in middle.
PostPosted: Mon Jan 29, 2018 2:23 pm
My answer was within about 3.66% of yours Doc :lol: 8) :P
